| Issue ID | Description |
| CFD-9256 (02740906, 02762111, 02858831) |
IQE: ASCOM iP62 randomly drops calls on roaming failures. |
| CFD-10640 (02903895) |
The AP302W Kernel and Hardware Watchdog crashes on 10.6.5. |
| CFD-10962 (02926088) |
Universal APs: Beacons do not show updated WMM QoS values for Contention Window Min and Max. |
| CFD-10995 (02901029) |
The length of R0KH-ID in the Reassociation Response is incorrect, causing an R0KH-ID mismatch and some clients to drop down the connectivity accordingly. |
| CFD-11040 (02929452) |
[IQE] Delta config push issue sometimes causes ACL to not work as the AP IP-policy (firewall). |
| CFD-11050 (02921799) |
[IQE] AP510C 10.6.6 getting "ah_auth" crash, often causing the client to reconnect, due to 32 characters limit. |
| CFD-11167 (02938970) |
PPSK self registration: Security vulnerability with captive portal solution. |
| CFD-11169 (02918590) |
Improper redirect—PPSK Self registration. |
| CFD-11304 (02946092) |
AP5010s unable to establish a CAPWAP connection until after reset. |
| HOS-20556 | We increased the Dynamic Packet Capture file size from 50kb to 100k to address a scenario were captures were not showing up. |
| HOS-20803 | We resolved an issue with Client Monitor 2.0 and Dynamic Packet Capture not working for WPA3-ENT protected SSIDs. |
| HOS-20992 | We resolved an issue with the AP5020 ETH0 Wired speed showing as 10Mbps instead of 10Gbps on the D360 Wired Interface. |
