ipmitool is a command line utility that enables interacting with devices that support IPMI. You can use this tool to monitor and manage such devices.
On Extreme Networks devices that have BMC, the BMC supports a subset of commands that can be executed through the ipmitool. The following commands are supported:
| Command | Description |
| power | power is a shortcut for the chassis power set of commands. on, off, cycle, and reset options are supported. |
| sensor | Prints detailed sensor information. Only list and get options are supported. |
Warning
Extreme strongly recommends to use the above listed ipmitool options only. Using any other option may cause the switch to become unstable.
Section contents:
