Assuming a correct IP address and correct
login credentials, failure to access the device using SSH or Telnet could be for one of the
following reasons:
SSH or Telnet is disabled. (Verify by entering
show telnet server
status or show ssh server status.)
The management port is down.
Access to the management interface is denied
by an ACL.
Checking for a deny ACL On the system console, enter the show running-config interface management command and check the output to determine whether an ACL is denying access to the management port.
