brocade-aaa
Top-level container
module: brocade-aaa
+--rw aaa-config
| +--rw aaa
| +--rw authentication
| | +--rw login
| | +--rw first? enumeration
| | +--rw second? enumeration
| | +--rw third? enumeration
| +--rw accounting
| | +--rw exec
| | | +--rw defaultacc
| | | +--rw start-stop
| | | +--rw server-type? acc_srv_type
| | +--rw commands
| | +--rw defaultacc
| | +--rw start-stop
| +--rw authorization
| +--rw command
| +--rw firstauthor? enumeration
| +--rw secondauthor? enumeration
+--rw username* [name]
| +--rw name string
| +--rw user-password user-passwd
| +--rw encryption-level? enumeration
| +--rw role string
| +--rw desc? string
| +--rw enable? username-enable
| +--rw expire? date
| +--rw access-time? string
| +--rw end-time? string
| +--rw acct-inactivity-expiry-period? uint32
| +--rw acct-inactivity-warning-period? uint32
+--rw service
| +--rw password-encryption? empty
+--rw user
| +---x unlock
| +---w input
| | +---w username string
| +--ro output
| +--ro Result? string
+--rw role
| +--rw name* [name]
| +--rw name string
| +--rw desc? string
+--rw radius-server
| +--rw host* [hostname use-vrf]
| +--rw hostname string
| +--rw use-vrf common-def:use-vrf
| +--rw radius-server-options
| +--rw auth-port? rad-auth-port
| +--rw protocol? rad-auth-protocols
| +--rw key? string
| +--rw retries? uint32
| +--rw timeout? uint32
| +--rw radsec? empty
| +--rw source-interface
| +--rw source-interface-name? track-iftype
| +--rw ethernet
| | +--rw source-interface-value? interface:interface-type
| +--rw loopback
| | +--rw source-interface-value? loopback-iftype
| +--rw ve
| | +--rw source-interface-value? ve-iftype
| +--rw management
| +--rw source-interface-value? mm-iftype
+--rw tacacs-server
| +--rw tacacs-server-options
| +--rw port? tac-auth-port
| +--rw protocol? tac-auth-protocols
| +--rw key? string
| +--rw retries? uint8
| +--rw timeout? uint8
| +--rw tacacs-source-ip
| +--rw tacacs-source-int-type? srcip_type
| +--rw tacacs-source-int-value? string-type
+--rw ldap-server
| | +--rw ldap-server-options
| | +--rw ldaps? empty
| | +--rw port? ldap-auth-port
| | +--rw basedn? string
| | +--rw source-intf-type? source-interface-type
| | +--rw ethernet
| | | +--rw source-intf-name? ethernet-iftype
| | +--rw loopback
| | | +--rw source-intf-name? loopback-iftype
| | +--rw ve
| | | +--rw source-intf-name? ve-iftype
| | +--rw management
| | +--rw source-intf-name? mm-iftype
| +--rw maprole
| +--rw group* [ad-group]
| +--rw ad-group string
| +--rw switch-role string
+--rw password-attributes
| +--rw min-length? uint32
| +--rw max-logins? uint32
| +--rw max-retry? uint32
| +--rw max-lockout-duration? uint32
| +--rw history? uint32
| +--rw repeat? uint32
| +--rw sequence? uint32
| +--rw force-default-password-change? empty
| +--rw max-password-age? uint32
| +--rw expiry-alert-level
| | +--rw info? uint32
| | +--rw minor? uint32
| | +--rw major? uint32
| | +--rw critical? uint32
| +--rw character-restriction
| | +--rw upper? uint32
| | +--rw lower? uint32
| | +--rw numeric? uint32
| | +--rw special-char? uint32
| +--rw admin-lockout-enable? empty
| +--rw login-notify-duration? uint32
+--rw banner
| +--rw login? string
| +--rw motd? string
| +--rw incoming? string
+--rw rule* [index]
| +--rw index uint32
| +--rw action? rule-action
| +--rw operation? rule-operation
| +--rw role? string
| +--rw command
| +--rw (cmdlist)?
| +--:(container-cmds)
| | +--rw enumList? enumeration
| +--:(interface-a)
| | +--rw interface-int
| | +--rw interface-cont!
| +--:(interface-c)
| | +--rw interface-eth
| | +--rw interface
| | +--rw ethernet-cont!
| +--:(interface-e)
| | +--rw interface-eth-leaf
| | +--rw interface
| | +--rw ethernet-leaf? interface:interface-type
| +--:(interface-f)
| | +--rw interface-mgmt
| | +--rw interface
| | +--rw management-cont!
| +--:(interface-i)
| | +--rw interface-pc
| | +--rw interface
| | +--rw port-channel-cont!
| +--:(interface-j)
| | +--rw interface-pc-leaf
| | +--rw interface
| | +--rw port-channel-leaf? interface:portchannel-type
| +--:(interface-m)
| | +--rw interface-management-leaf
| | +--rw interface
| | +--rw management-leaf? interface:man-interface-type
| +--:(interface-n)
| | +--rw interface-loopback
| | +--rw interface
| | +--rw loopback-cont!
| +--:(interface-o)
| | +--rw interface-loopback-leaf
| | +--rw interface
| | +--rw loopback-leaf? loopback-intf:intf-loopback-port-type
| +--:(interface-p)
| | +--rw interface-ve
| | +--rw interface
| | +--rw ve-cont!
| +--:(interface-q)
| | +--rw interface-ve-leaf
| | +--rw interface
| | +--rw ve-leaf? interface:ve-type
| +--:(copy-a)
| | +--rw copy-cp
| | +--rw copy-cont!
| +--:(copy-b)
| | +--rw copy-running
| | +--rw copy
| | +--rw running-config-cont!
| +--:(copy-c)
| | +--rw copy-support
| | +--rw copy
| | +--rw support-cp!
| +--:(clear-a)
| | +--rw clear-cl
| | +--rw clear-cont!
| +--:(clear-b)
| | +--rw clear-logging
| | +--rw clear
| | +--rw logging-cont!
| +--:(clear-c)
| | +--rw clear-support
| | +--rw clear
| | +--rw support-cl!
| +--:(protocol-a)
| | +--rw protocol-pr
| | +--rw protocol-cont!
| +--:(protocol-b)
| | +--rw protocol-spanning
| | +--rw protocol
| | +--rw spanning-tree-cont!
| +--:(protocol-c)
| +--rw protocol-lldp
| +--rw protocol
| +--rw lldp-cont!
+--rw root-sa
| +--rw root
| +--rw enable? empty
| +--rw access? root_access_type
+--rw alias-config
+--rw alias* [name]
| +--rw name string
| +--rw expansion string
+--rw user* [name]
+--rw name string
+--rw alias* [name]
+--rw name string
