Before adding a new node, you must configure the new controller and ensure that it is running the current software version. Refer to Prepare to Replace a Node.A node is one appliance. Universal Compute Platform clusters typically support up to three or more nodes, with the ability to scale up when the cluster reaches capacity.
To add a node to a cluster, take the following steps:
