Discovery and Registration
Wireless devices (APs and SA201 adapters) discover the IP address of ExtremeCloud IQ Controller using a sequence of mechanisms that allow for the possible services available on the enterprise network. The discovery process is successful when the AP/adapter successfully locates a controller to which it can register. Ensure that the appropriate services on your enterprise network are prepared to support the discovery process.
The following subnets are reserved for internal communications and Docker operations:
  • 172.17.0.0/24
  • 172.31.0.16/28
The ExtremeCloud IQ Controller user interface logic prevents adding addresses in these address ranges for VLAN interface references.
An access point can learn a hostname from a DHCP server. The AP reports either the discovered hostname, or an internally generated hostname (which is the AP serial number) to the controller as part of the discovery process.
Enhanced Discovery can be used to enhance support of onboarding for Local Management (within ExtremeCloud IQ) providing an option to define the list of primary and secondary controllers running ExtremeCloud IQ Controller For more information, see Enhanced Discovery.
Enhanced Discovery is supported on AP3000 and ExtremeCloud IQ Controller.
