AP5000 Series Power Management
AP5000 Series Power Consumption Widget
ExtremeCloud IQ Controller offers a power consumption widget for the AP5000 series access points (AP5010, AP5020, AP5022/FX/SD6, AP5050D/U, AP5060D/U). This widget offers a visual display of the power consumption for the AP over the display period.
To access the Power Consumption widget:
  1. Go to Monitor > Devices > Access Points.
  2. Select an access point from the Access Points List.
  3. To edit the AP dashboard, select
  4. Select Widgets > Power > Power Consumption.
  5. Drag the Power Consumption widget icon onto the dashboard.
AP5010 Power Consumption Widget
AP5010 Power Source Feature Restrictions
Depending on the power source that is reported to ExtremeCloud IQ Controller, the AP5010 has the following restrictions.
Table 1. AP5010 feature restrictions related to the power source provided to the AP
Power StatusHighNormalLowNormal
Power Source802.3BT802.3AT802.3AFPower Supply
PSE= OFFOFFOFFOFF
All 3 Radios operate 2x2
Maximum Tx 10 dBm
OFF
PSE=AutoONOFFOFFOFF
USB=OFFOFFOFFOFF
USB=AutoONON
All 3 Radios operate 3x3
OFFON
All 3 Radios operate 4x4
AP5020 Power Source Information
The AP5020 power values differ from other 5000 series APs and legacy APs. The most restrictive power connection is listed instead of the highest level power connection. This is to support AP power redundancy. The level of service provided does not change if any of the power connections fails. For more details on the AP5020 power profile, refer to the Extreme Wireless 802.11be Wi-Fi 7 Indoor AP5020 Access Point Installation Guide.
AP5050 Power Source Information
The AP5050U and AP5050D access points do not include a USB port or an external power supply. These outdoor access points operate on standard power.
Table 2. AP5050 power source provided to the AP
PSE= OFFOFFOFF
PSE=AutoONOFF
