AP Tunnel Information
The VLANS tab for a selected device provides status information on the AP tunnel between the AP and the appliance, both for single deployments and for an availability pair. For devices configured with a VxLAN topology, it displays status information for the VxLAN tunnel.
Supported on AP models that use Wi-Fi 6 or higher standards.
To view tunnel status information:
  1. Go to Monitor > Devices > Access Points.
  2. Select an AP.
  3. Select VLANS.
AP Tunnel
This information does not pertain to the GRE Point-to-Point Tunnel feature, which supports tunneling traffic between access points without traversing the controller.
The following information displays for the AP tunnel between the selected AP and the appliance:
IP Address
The IP address of the appliance. In an availability pair, the primary appliance is listed first.
Status
Operational status of the AP Tunnel. Valid values are: Normal and Failed.
Type
Indicates the controller in an availability pair. Valid values are: Active or Backup, referring to the Primary Appliance or Backup Appliance, respectively.
Configured MTU
The Maximum Transmission Unit (MTU) setting for the AP. With Jumbo Frames, this can be up to 1800 bytes. AP MTU is configured in the device group configuration Profile or as an AP override.
Configured MTU Tunnel Status
The status of the MTU tunnel between the selected AP and the appliance. Valid values are Normal and Failed. When the Configured MTU value is set to 1800 and this tunnel fails, it indicates that a router in the chain between the AP and the appliance does not support the Jumbo Frames value of 1800 bytes. The MTU values for all devices in the path from AP to appliance must match.
Path MTU Learned by AP
When a router does not support the MTU setting of 1800 bytes, it sends a message back to the AP indicating the MTU value it can support. If necessary, reconfigure the Configured MTU value for this AP to match the router setting. The MTU values for all devices in the path from AP to appliance must match.
Internal Management Tunnel
The status of an internal tunnel within ExtremeCloud IQ Controller. Valid values are Normal, Failed, and MTU Failed. If this tunnel fails, contact Extreme Networks Support.
VLANS
The following information displays for configured VLANS:
Name
Topology Name
Mode
Topology type. Valid values are:
  • Bridged@AP
  • Bridged@AC
  • Fabric Attach
  • VxLAN
Tagged
A check mark indicates that VLAN is tagged. If you have more than one VLAN on a port, enable tagging to identify to which VLAN the traffic belongs. Ensure that the tagged vs. untagged state is consistent with the switch port configuration. Fabric Attach topologies are always tagged.
VLAN ID
Identifies the VLAN.
For Fabric Attach. A unique VLAN identifier and a unique I-SID (service identifier). The I-SID range is (0-15999999).
Certificates
Indicates that a certificate has been applied to the AP.
Remote VTEP
For VxLAN. The IP address of the tunnel End-Point is referred to as a VxLAN Tunnel Endpoint (or VTEP). The VTEP is the IP address of the network switch. Network switches that act as a VTEP are referred to as VxLAN gateways. There can only be one VTEP per VxLAN topology.
VNI
For VxLAN. VxLAN Network Identifier. The VNI is a 24-bit identifier. It can be used in more than one VxLAN topology.
Tunnel Status
For VxLAN. Status of the VxLAN tunnel. Valid values are Normal, Failed, and MTU Failed. MTU Failed indicates that the VxLAN MTU setting of 1550 bytes is not supported on another device in the chain between the AP and the appliance. The MTU values for all devices in the path from AP to appliance must match.
