A secure Inter-Controller Data Tunnel (ICDT) that uses IKE/IPSEC.
The load balancing method used for AP traffic destined for the availability pair.
| Field | Description |
| Standalone / Paired | Select a deployment mode:
| Role | Select the role of the paired appliance. Options are:
Note: The configuration of the Primary appliance is copied to the Secondary appliance.
| Peer IP Address | Physical VLAN address of the paired appliance. This is the IP address of the "Physical 1" interface (port esa0), which matches the VLAN definition under System > Interfaces. |
| Auto AP Balancing | Select the load balancing configuration for the availability pair. In an availability pair, an AP establishes an active tunnel to one appliance and a backup tunnel to the other appliance. The active tunnel is used to pass the client data over tunneled topologies.
| Secure Tunnel | Select to enable a secure ICDT tunnel that uses IKE/IPSEC. This option is disabled by default. |
| MTU [Bytes] | Use the spinner to set the Maximum Transmission Unit (MTU) to avoid data packet fragmentation. Set a value in the range 600–1800 bytes. The default value is 1500 bytes. Important: When MTU is 1800, ensure that Jumbo Frames is enabled on the Switch.
