Configure policy rules that are associated with a role from the Role
Configuration page. To configure an OSI Layer 3 and 4 rule, which
filters on IP Address and Port number:
- Select the L3, L4 Rules (IP and Port) Rules drop-down and
select New
or select the rule to edit and existing rule.
- Configure the following
parameters:
- Name
- Name the rule.
- Action
- Determines access control action for the
rule. Valid values are:
- None - No role defined
- Allow - Packets contained to role's default action's
VLAN/topology
- Deny - Any packet not matching a rule in the policy is
dropped.
- Contain to VLAN - A topology to
use when a network is created using a role that does not specify a topology. (Not applicable for L7
Application Rules.)
- COS
- Determines the importance of a frame while it is forwarded
through the network relative to other packets. The CoS defines actions to be taken when rate
limits are exceeded.
- Protocol
- The user defined protocol or protocol type associated
with the defined rule. Traffic from this protocol is subject to the defined rule. Valid
values are:
- User Defined, then specify a protocol that is not already in the
list. Use this option to explicitly specify a protocol that is not listed.
- A specific protocol from the list.
- IP Subnet
- Specify the IP address or subnet address associated with
the defined rule. Traffic from this address is subject to the defined rule. Valid
values are:
- User Defined. Specify the destination IP address and mask. Use this option to explicitly
define the IP/subnet aspect of the rule.
- Any IP - Maps the rule to the associated Topology IP address.
- Select a specific subnet value - Select to map the rule to the
associated topology segment definition (IP address/mask).
- FQDN
- Allows for filtering on fully qualified domain names.
- Other subnet options include:
- Sepectralink Mcst
- Vocera Mcst
- mDNS/Bonjour
- Port
- The port or port type associated
with the defined rule. Traffic from this port is subject to the defined rule. Valid values
are:
- User Defined, then type the port number.
Use this option to explicitly specify the port number.
- A specific port type. The appropriate port number or numbers are added to
the Port text field.
- Select
Save.
All rule types are
applied to the policy in top to bottom order. The policy is installed on the
enforced APs.
