The ExtremeCloud IQ Controller RF Management policy depends on your AP model. AP models that use Wi-Fi 6 or higher standards support Smart RF as the RF Management policy. ExtremeCloud IQ Controller is installed with a default Smart RF policy.
You can modify the default policy or create a new policy. Policies that are being used by a device group cannot be deleted, but if the policy is not being used, you can delete it. Multiple Smart RF policies can be assigned to a site.
The RF Management value is Smart RF for AP models that use Wi-Fi 6 or higher standards.
ExtremeCloud IQ Controller is installed with a default Smart RF policy. You can modify the default policy or create a new policy, but you cannot delete a Smart RF policy.
After modifying the default RF policy settings, if you need to return to the ExtremeCloud IQ Controller initial settings, create a new Smart RF policy. New policies are comprised of the Smart RF settings that are delivered with the initial ExtremeCloud IQ Controller installation. Select
