To configure the
ExtremeGuest server, take the following steps:
- Go to and select Add.
- Configure the following parameters:
- IP Address
- IP address of the ExtremeGuest server.
- Name
- Name of the ExtremeGuest server.
- FQDN
- Fully-qualified domain name of the ExtremeGuest server.
- Authentication Timeout Duration (Seconds)
- Determines a timeout value, in seconds, for the RADIUS server
connection.
- Authentication Retry Count
- Determines the number of times ExtremeCloud IQ
Controller will
attempt to authenticate an end user.
- Authorization Client UDP Port
- User Datagram Protocol (UDP) port number used for client
authentication. UDP needs only one port for full-duplex, bidirectional traffic.
- Accounting Client UDP Port
- UDP port number used for client accounting. User
Datagram Protocol (UDP) needs only one port for fullduplex,
- Shared Secret
- The password that is used to validate the connection between ExtremeCloud IQ
Controller and the ExtremeGuest server.
- Mask—Determines if the Shared Secret or password value is displayed on the user
interface. Enable Mask to display dots in place of the Shared Secret or password value. To
display the password characters, clear the Mask check box.
- ExtremeGuest User Name
- User ID that ExtremeCloud IQ Controller Callback Manager uses to access the ExtremeGuest server.
- ExtremeGuest Password
- The password that ExtremeCloud IQ Controller Callback Manager uses to access the ExtremeGuest server. The minimum password length is 6 characters.
