GRE Topology
A Generic Routing Encapsulation (GRE) topology traverses wireless client traffic from a campus AP to a locally managed Extreme Networks Tunnel Concentrator or third-party GRE terminating device. GRE tunneling supports traversing client traffic through positioned access points at a location separated from ExtremeCloud IQ Controller.
The GRE Point-to-Point tunneling feature makes use of the Internet Control Message Protocol (ICMP). This is a network level protocol that communicates network connectivity issues back to the source of the compromised transmission. When more than one GRE concentrator is configured on a topology, access points use ICMP ping to check connectivity between the access point and the GRE concentrator. When the ICMP ping to concentrator fails, the access point selects the next configured concentrator as a destination for the GRE tunnel. The communication ports on each device must be open to allow ICMP communication between the access points and GRE concentrators.
Supported APs
The following Universal Access Points support GRE Point-to-Point Tunneling:
  • Wi-Fi 7 APs
    • AP3020W
    • AP4020/X/FX
    • AP4060/X
    • AP5020
    • AP5022/FX/SD6
    • AP5060U/D
  • Wi-Fi 6E APs
    • AP3000/X
    • AP4000
    • AP4000-1
    • AP5010
    • AP5050D/AP5050U
  • Wi-Fi 6 APs
    • AP302W
    • AP305C/CX
    • AP305C-1
    • AP310i/e
    • AP410C
    • AP410C-1
    • AP460C/S6C/S12C
Performance can vary depending on the AP model.
APs communicate through the GRE tunnel. Although each AP can support many GRE topologies, a single assigned topology supports three concentrators. IPv6 is not supported.
Each AP issues a ping to the GRE concentrator to determine reachability. If there is no response within 30 seconds, the AP fails over to a backup concentrator.
AP Events
The following AP events address tunnel status:
  • Connection is Up (Info) — An event is generated when the connection to any VPN Concentrator is established.
  • Connection is Down (Major) — An event is generated when the connection is lost to a particular concentrator.
It is a best practice to configure more than one Tunnel Concentrator per VLAN topology for failover. A topology that uses a single generic (non-encrypted) GRE tunnel, without configured backups, is not using the available mechanisms to detect if a Tunnel Concentrator is down. Therefore, no AP alarms, related to the tunnel connectivity, are generated for such a topology.
