If internet access is not available for continuous connectivity to the cloud server, you can install an air gap licensing file that is generated from the Extreme Networks Support Portal.From the License Details tab, select Switch to Air Gap Licensing to install the air gap file.
To synchronize the controller with the LEM server on demand, select Synchronize Now.
The hardware appliances and access points have Extreme CA certificates installed. Also, both a temporary and permanent subscription license for a virtual controller includes a PKI Certificate. For information about certificates, see Certificates.
Cloud connectivity (
