Network Snapshot: Clients Dashboard
The Clients screen displays information and details about a specific client, as well as the client location on a mapped floor plan.
To access the Clients screen:
Go to Clients and select a client from the list.
Information about the selected client is displayed.
Table 1. Client Information
Client MAC address and statusAccess Point
Client IP Address SSID
IPv6 Address (if applicable) Radio
Last SiteRSS
Last Seen (on the network, including date and time)Protocol
ManufacturerChannel
Default VLANTx Rate 1
RoleRx Rate 1
GroupsDevice Family
Device Type
Host Name
MLO Mode (STR, EMLSR, or MLSR)
MLO Radios
Notes:
1 When the client MLO Mode is STR, the TX Rate and RX Rate reported here represent the aggregated rate of both links; whereas when the client MLO Mode is EMLSR, the TX and RX rates reported represent the current rate of the link with the highest rate.
The Client Details displays a chart of client association with an AP.
Table 2. Tabs on the Client Screen
TabDescription
DashboardNetwork charts provide throughput, volume, and speed information for each client. Use this information to understand network traffic and load.
SitesLists sites associated with the client.
NetworksLists the network services associated with the client. Select a network to display network details. See WLAN Service Settings .
Access PointsLists access points associated with the client. Use the search facility to find a specific AP. The AP Name that you specify is displayed by default.
Station EventsLog of station events for the client. Use the search facility to locate a specific event. Search on any column heading. To enable station events, go to Admin > System > Logs and check Send Station Events.
