To view network details from the switch screen:
| Tab | Description |
| Dashboard | Widgets display network details related to the selected switch. |
| Ports | A list of configured ports on the selected switch. |
| LAG Ports | Link Aggregation Group (LAG) Ports organized as a list of master ports and the LAG members that are associated with the master port. All ports assigned to a LAG must have the same port function. The configuration of the master port is shared with its LAG members. When a port is added to a LAG, its previous unique configuration is removed and the port inherits the group configuration. Note: A Link Aggregation Group whose function is to connect to an AP is limited to two ports in the group. Both ports must negotiate to the same speed (1 Gbps).
LAG is supported on ExtremeWireless AP39xx and AP models that use Wi-Fi 6 or higher standards (excluding AP305C, AP410C, and AP460C). |
| Traces | Trace information related to the selected switch. |
| VLANS | A list of VLANs associated with the switch, including the switch port number. |
| Troubleshooting | Provides a remote console to enable diagnostic debugging of ExtremeXOS switches. |
