Site-Level RADIUS Configuration for Switches
ExtremeCloud IQ Controller supports direct access from a switch to an external RADIUS server within the site configuration. You can associate up to two RADIUS servers for accounting and two RADIUS servers for authentication.
When using 200 Series switches, only one accounting server is supported.
You must first configure the RADIUS servers before you can associate them to switches in a site configuration.
  1. Configure each RADIUS server.
    Go to Onboard > AAA > RADIUS Servers.
  2. Associate the RADIUS servers to the switches within the site configuration.
    1. Go to Configure > Sites and select a site.
    2. Select the Switches tab.
    3. Configure the following parameters:
    MSTP
    Enable the MSTP (Multiple Spanning Tree Protocol) to optimize load balancing.
    AAA Policy
    Refer to external RADIUS servers directly without proxy by NAC. For configuration steps, see AAA Policy Network Configuration.
    Switches
    Check the switches that are associated with the site.
