Supported APs for AFC in Canada and the United States
Supported APs lists Extreme Universal APs that are approved for AFC deployment in Canada and the United States and specifies which APs support Standard Power (SP) 6 GHz operation.
The following table uses the term composite device. A composite device is a non-anchor AP capable of operating in both Standard Power (SP) and Low Power Indoor (LPI).
Table 1. Supported APs
APIntegrated GPS Unit6 GHz LPI6 GHz SP
Outdoor APs
AP4060YesNoYes
AP4060XYesNoYes
AP5050D YesNoYes
AP5050U YesNoYes
AP5060DYesNo 1Yes
AP5060UYesNo 1Yes
Indoor APs
If you deploy the following APs as anchor APs, then you will have to use the ExtremeCloud IQ Mobile Companion app (AFC Mobile app) to acquire GPS coordinates for an AP.
AP3000 NoYesYes
AP3000X NoYesYes
AP3020WNoYesYes
AP4000 NoYesYes
AP4000-1 NoYesNo
AP4020
(composite device)
NoYesYes
AP4020X (composite device)NoYesYes
AP4020FX NoNoYes
AP5010 (composite device) NoYesYes
AP5020 (composite device) NoYesYes
AP5022NoYesYes
AP5022FXNoNoYes
AP5022SD6NoYesYes
Notes:
  1. Restricted AP5060 SKUs are available for deployment explicitly in large venues in the U.S. that have an on-premise ExtremeCloud IQ Controller. These composite devices support both low power indoor (LPI) operation and indoor 6 GHz standard power (SP) operation under AFC control with fallback to LPI operation. Restricted AP5060 SKUs are AP5060D-WW-LPI and AP5060U-WW-LPI.
