You can create an AFC report by drawing a polygon around a specific area on a map, then export it to your local machine.
Note the following interpretation of the reported TX powers:
The AFC Explorer provides a channel/power in the range of 0 to 36 dBm EIRP over the whole or part of the selected venue.
The actual TX power that can be transmitted by the AP5050U/D is in the range of approximately 12 to 21dBm EIRP.
- Any channel allowing less 12dBm is unusable as the AP cannot transmit less than 12dBm due to antenna and chain gain.
- Any power restriction between 21 and 36dBm can be ignored as the AP cannot transmit over 21dBm due to FCC outdoor regulation 21dBm EIRP at any elevation angle above 30 degrees.
- Select
- Enter the following information:
Name - The name of the report.
Height [m] - The elevation maximum to scan for access points.
Country - The country to select data for.
- Create the area to report by using the mouse to create a polygon over the map.
- To narrow the range of the displayed area, select Search for … at the top of the map and enter the name of the area you want to zoom down to.
- Select and drag the map to the geographic location you want to create the report for. Use the Zoom In
or Zoom Out
buttons to zoom in or out. You can also use the mouse wheel. - Select a beginning point for the boundary to the report. As you move the mouse, a line is drawn to indicate the boundary.
- Select a new location to create each new vertex of the polygon that defines the boundary.
- When the boundary is fully defined, select on the first point you drew to stop creating the polygon.
If you make a mistake, select
Clear and redraw the polygon.
You can create up to a maximum number of 15 vertices.
- Select Query AFC Server to create the AFC report.
- Under Access Points, select individual access points from the list to view details, and indicate which data is included in the AFC report.
Selecting an individual AP from the pulldown list also highlights the selected AP on the map. This is helpful to identify which area in the polygon has a low or probelmatic allowed power.
- To view the latitude and longitude for an individual access point, select it on the map.
- Select Export AFC Report to export the channel and allowed power value for all APs returned by the AFC server, independent of which APs are selected.
Use this to perform further analysis of channels and power with external tools.
- Indicate the local folder to save the report.
The exported AFC report downloads to your computer, and can be accessed offline.
