License notifications and violation banners include a link to the Affected
Devices table. Some table columns are specific to the license
notification or violation banner.
Devices with active grace period or unlicensed:
The table shows
devices that are using the grace period and the date the grace period ends.
The table also
differentiates between devices that are using the grace period, and
devices that do not have licenses:
The LICENSE column shows the type of license, for
example: CoPilot.
The
STATUS column shows whether the device is using the
grace period, or
unlicensed.
The GRACE PERIOD END
DATE column shows the date on which the grace period
expires.
Devices with Expiring Licenses:
The table shows devices with
licenses approaching the expiration date.
The License column shows the type of license.
The Subscription End Date column shows the
date on which the license will expire.
