The Summary screen displays map-based views and active user summaries.
The Summary is divided into to two sections: The left-panel tree and the right-panel Summary Details. Use the left-panel tree to navigate to sites within your networks. Expand the tree and select a site to display user information specific to that site location.
The Summary screen provides a high-level overview of user activity over the past 24 hours, which updates automatically.
The bar at the top of the window displays information about the total number of users and the total number of users online.
If social media authentication is enabled, the number of users authenticated using Google or LinkedIn also displays. The Summary Details panel displays additional summary information.
The Map View is divided into to two sections: The left-panel tree and the right-panel map.
Use the left-panel tree to navigate to sites within your networks. Expand the tree and select a site to refocus the map to that site location.
The bar at the top of the screen provides information about the total number of users and the total number of users online.
If social media authentication is enabled, the bar will also display the number of users authenticated using Google or LinkedIn.
| Map View Control | Location | Description |
| Bottom-right corner of the map | Drag and drop the icon on a specific area on the map to display a street view of the area. | |
| Bottom-right corner of the map | Use to zoom in and out on the map. | |
| Top-right corner of the map | Use to open the map in full-screen mode. Select the [Esc] button to exit full-screen mode. | |
| Top-left corner of the map | Use to toggle between map view and satellite view. You can also add Terrain details to the map view and labels to the satellite view. |
Section contents:
