An action has failed because of resource shortage. The operation of OSPF may be affected. For example, adjacencies may not be set up with neighbors.
Check for other logs that indicate the action that has failed. Allocate more resources to the OSPF system. If the problem persists then please contact support.
Error
%p1% An action has failed because of resource shortage.
| Name | Type |
| p1 | String |
