Communication with a neighbor has failed because of an internal error. An adjacency cannot be set up with the neighbor.
Check for other logs that indicate the cause of the error, for example logs of resource failures. If the problem persists then please contact support.
Error
%p1% %p2% %p3% %p4% Communication with neighbor has failed because of an internal error.
| Name | Type |
| p1 | String |
| p2 | String |
| p3 | String |
| p4 | String |
