No MEP object found corresponding to a port on the ring. MEP not configured for the ring
Use 'show erps <ring>' and 'show cfm <domain>' commands. Check ring CFM parameters, port values and control VLAN. Configure CFM parameters for the ring containing valid ring ports.
Warning
No MEP object exists for ring: %ring% in-port: %slot%:%port% vlanInst: %vlanInst%
| Name | Type |
| ring | String |
| slot | uInt32 |
| port | uInt32 |
| vlanInst | uInt32 |
