Port is not configured as part of any ERPS ring. The info could not be sent to the VLAN Mgr
Check the ring port statistics using the 'show port <port>' and 'show port <port>' statistics commands. Check VLAN port interface states
Warning
Could not send mesage to VLAN manager to inform port with index %index% config change for ring %ring%
| Name | Type |
| index | uInt32 |
| ring | String |
