HAL.IPv4ACL.LkupInstFail
Description
There is no such instance in the ACL database.
Remedy
Disable and re-enable the slot and try again.
Severity
Error
Message Text
Unable to get the instance based on index vlan %vlan% port %port% precedence %pre% direction %dir%
Message Parameters
Name Type
vlan uInt
port uInt
pre uInt
dir uInt
