ISIS.IIH.RxExtCircIdNoMatch
Description
A 3-way handshake TLV in a point-to-point Hello PDU did not contain the correct neighbor (this router's) circuit ID.
Remedy
Packets may be leaking to the wrong VLAN and ISIS interface via a network misconfiguration. Confirm that only two ISIS routers are participating in this point-to-point adjacency and that hello packets cannot cross to other VLANs.
Severity
Notice
Message Text
%pduType% IS-Neighbor(%vlanName%-%sysId%) Extended Circuit ID mismatch in 3-way TLV
Message Parameters
Name Type
pduType String
vlanName VLAN
sysId String
