ISIS.IIH.RxNbrAddLocalFail
Description
While attempting to add a new neighbor to the receiving interface's neighbor database, the system ID was already associated with the interface.
Remedy
This is a "should never" happen scenario because the receiving interface's database is checked for the neighbor system id before attempting to add it. If the problem persists and/or an adjacency fails to form on the interface, try removing the afflicted from ISIS and re-adding it.
Severity
Notice
Message Text
[%vlanName%-%sysId%] Local Neighbor Database insertion failed
Message Parameters
Name Type
vlanName VLAN
sysId String
