VPEX.Ring.Unsuprt
Description
A connection has been discovered between 2 VPEX cascaded daisy chains. However, the specified slot does not support ring topology operation in this version of EXOS.
Remedy
Check whether ring topology is supported on this slot type in a subsequent version of EXOS and consider upgrading if so.
Severity
Warning
Message Text
Slot %slot% does not support ring topology in this version of EXOS which is preventing ring detection between ports %port1% and %port2%
Message Parameters
Name Type
slot Slot
port1 SlotPort
port2 SlotPort
