Edge License Features
The Edge License includes all Value Edge license features and the features in Edge License Features. The Edge License is standard for the following switches:
  • ExtremeSwitching X440-G2
    Upgradeable to Advanced Edge
  • ExtremeSwitching X450-G2
Table 1. and Switch Engine Edge License Features
Software feature Supported platforms
Extended Edge Switching X465
Convergence End Point (CEP) detection All Edge License platforms
Direct Attach—based on the IEEE version of VEPA, eliminates the virtual switch layer, simplifying the network and improving performance. Direct Attach enables data center simplification by reducing network tiers from four or five tiers to just two or three tiers, depending on the size of the data center. All Edge License platforms
CLEAR-Flow All Edge License platforms
System virtual routers (VRs) All Edge License platforms
DHCPv4:
  • DHCPv4 server
  • DHCv4 client
  • DHCPv4 relay
  • DHCPv4 smart relay
DHCPv6:
  • DHCPv6 relay
  • DHCPv6 prefix delegation snooping
  • DHCPv6 client
  • DHCPv6 smart relay
  • DHCPv6 remote ID
User-created virtual routers (VRs)
Virtual router and forwarding (VRF)
X450-G2, X460-G2, X465, X695
Local-only, user-created virtual routers (VR) X435, X440-G2
VLAN aggregation All Edge License platforms
Multinetting for forwarding All Edge License platforms
UDP Forwarding
UDP BootP relay forwarding All Edge License platforms
IPv4 unicast routing, including static routes All Edge License platforms
IPv4 multicast routing, including static routes
Note: This feature has limitations in the Edge and Advanced Edge licenses. See the ExtremeXOS v33.6.1 User Guide .
IPv4 Duplicate Address Detection (DAD) All Edge License platforms
IPv6 unicast routing, including static routes All Edge License platforms
IPv6 interworking—IPv6-to-IPv4 and IPv6-in-IPv4 configured tunnels All Edge License platforms, except X435 and X440-G2
IPv6 DAD without CLI management All Edge License platforms
IPv6 DAD with CLI management All Edge License platforms
IP security:
  • DHCP Option 82—L3 mode
  • DHCP Option 82—L3 mode VLAN ID
  • Disable ARP learning
  • Gratuitous ARP protection
  • DHCP secured ARP / ARP validation
  • Source IP lockdown
IP address security:
  • DHCP snooping
  • Trusted DHCP server
  • ARP validation
IP Flow Information Export (IPFIX) X460-G2
IP NAT X465, X695
Keychain Manager All Edge License platforms
Multi-Switch Link Aggregation Group (MLAG) All Edge License platforms
ONEPolicy All Edge License platforms
Policy based routing (PBR) for IPv4 All Edge License platforms
Policy based routing (PBR) for IPv6 All Edge License platforms
PIM snooping
Protocol-based VLANs All Edge License platforms
RIP v1/v2 All Edge License platforms
RIPng All Edge License platforms
Routing access policies All Edge License platforms
Route maps All Edge License platforms
SummitStack (switch stacking using native or dedicated ports) X460-G2 with X460-G2-VIM-2SS optional card, and X450-G2
SummitStack-V (switch stacking using dual-purpose data ports) All Edge License platforms, except X435. See the specific models listed in the "Support for Alternate Stacking Ports" section of the ExtremeXOS v33.6.1 User Guide .
SyncE X460-G2
Python scripting All Edge License platforms
Extreme Network Virtualization (XNV) All Edge License platforms, except X435
