Getting Help
  If you require assistance,
      contact Extreme Networks
      using one of the following methods:
   - Global Technical Assistance Center (GTAC) for Immediate Support
   - GTAC Knowledge — Get on-demand and tested resolutions from the GTAC
    Knowledgebase, or create a help case if you need more guidance.
   - The Hub —
        A forum for Extreme
        customers to connect with one another, get questions answered, share ideas and feedback, and
        get problems solved. This community is monitored by Extreme Networks employees, but is not
        intended to replace specific guidance from GTAC.
   - Support
      Portal — Manage cases, downloads, service contracts, product licensing, and
    training and certifications.
  Before contacting Extreme Networks for technical support, have the
      following information ready:
   - Your Extreme Networks service contract number and/or
        serial numbers for all involved Extreme Networks products
   - A description of the
    failure
   - A description of any
    action(s) already taken to resolve the problem
   - A description of your
    network environment (such as layout, cable type, other relevant environmental information)
   - Network load at the time
    of trouble (if known)
   - The device history (for
    example, if you have returned the device before, or if this is a recurring problem)
   - Any related Return Material Authorization (RMA)
    numbers
