Associate ports with an ACL
Associate ports with an ACL to apply filters to port traffic.
A port can be part of two different ACLs of different types: IPv6 and non-IPv6.
The ACL exists.
Variable definitions
Use the data in the following table to use the filter acl port command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
