View the Active RP
Perform this procedure to view information about the active RP for all the running multicast groups on the switch.
- Select PIM.
- Select the Active RP tab.
Active RP Field Descriptions
Use the data in the following table to use the Active RP tab.
Name |
Description |
GroupAddress |
Shows the IP address of the multicast group. |
Address |
Shows the IP address of the RP router. This address must be one of the local PIM-SM enabled interfaces. |
Priority |
Shows the priority of the RP. |
