View the IPv6 Active RP
Perform this procedure to view information about the IPv6 active RP for all the running multicast groups on the switch.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6 PIM.
  3. Select the Active RP tab.
Active RP Field Descriptions
Use the data in the following table to use the Active RP tab.
Name
Description
GroupAddress
Shows the IPv6 address of the multicast group.
Address
Shows the IPv6 address of the RP router. This address can be one of the local PIM-SM enabled interfaces or any reachable global IPv6 address configured using the static-rp CLI command.
Note:
IPv6 link local address is always used as the PIM interface address.
Priority
Shows the priority of the RP.
