Graph IPv6 VRRP Statistics
Use the following procedure to graph IPv6 VRRPv3 statistics for monitoring the network performance.
- Select VRRP.
- Select the Stats tab.
- Select an interface, and then select Graph.
- Select one or more values.
Select a graph type:
Line Chart
Area Chart
Bar Chart
Pie Chart
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
Name |
Description |
InetAddrType |
Shows the type of IP address (IPv4 or IPv6). |
ChecksumErrors |
Shows the number of VRRP packets received with an invalid VRRP checksum value. |
VersionErrors |
Shows the number of VRRP packets received with an unknown or unsupported version number. |
VrIdErrors |
Shows the number of VRRP packets received with an invalid VrID for this virtual router. |
