View IPv6 VRRP statistics for a VLAN or port.
Change the VRF instance as required to view IPv6 VRRP statistics on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
  1. In the navigation pane, expand Configuration > Edit > Port.
  2. Select IPv6.
  3. Select the VRRP tab.
  4. Select an interface.
  5. Select Statistics.
