The switch can query the number of ingress and egress IP multicast streams traversing the switch. After you configure the thresholds for ingress and egress records, if the record-usage goes beyond the threshold, the device notifies you by way of a trap on the console, logged message, or both.
If you do not configure the thresholds, the switch displays only the ingress and egress records currently in use.
Show the hardware resource usage:
Switch:1>show ip mroute hw-resource-usage ================================================================================ Multicast Hardware Resource Usage ================================================================================ EGRESS INGRESS EGRESS INGRESS LOG MSG SEND TRAP SEND TRAP REC IN-USE REC IN-USE THRESHOLD THRESHOLD ONLY ONLY AND LOG -------------------------------------------------------------------------------- 0 0 0 0 false false false
