Use PIM Debugging Commands
Use Protocol Independent Multicast (PIM) traces to aid in PIM troubleshooting.
The following table defines parameters for the debug ip pim command.
Variable |
Value |
assert |
Displays the assert debug traces. The default is false (disabled). |
bstrap |
Displays bootstrap debug traces. The default is false (disabled). |
group {A.B.C.D} |
Displays debug traces from a specific group IP address. The default is 0.0.0.0 (disabled). |
hello |
Displays hello debug traces. The default is false (disabled). |
joinprune |
Displays join and prune debug traces. The default is false (disabled). |
pimdbglog |
Logs debug traces. The default is false (disabled). |
pimdbgtrace |
Displays PIM debug traces. The default is false (disabled). |
rcv-dbg-trace |
Displays trace messages received by the switch. The default is false (disabled). |
register |
If enabled, the system displays register debug traces. The default is false (disabled). |
regstop |
Displays register stop debug traces. The default is false (disabled). |
rp-adv |
Displays RP advertisement debug traces. The default is false (disabled). |
send-dbg-trace |
Displays trace messages forwarded by the switch. The default is false (disabled). |
source {A.B.C.D} |
Displays debug traces from a specific source IP address. The default is 0.0.0.0 (disabled). |
