Use the following procedure to create graphs for chassis statistics.
- Select Chassis.
- Select the System tab.
System Field Descriptions
The following table describes the fields on the System tab.
Name |
Description |
MemUsed |
The percentage of memory space used. Only the AbsoluteValue column is valid in the System tab. All other columns display as N/A because they are percentages and not actual memory counters. |
MemFree |
The amount in kilobytes of free memory. |
CpuUtil |
Percentage of CPU utilization. |
