View Chassis SNMP Statistics
View chassis SNMP statistics to monitor network performance.
  1. In the Device Physical View, select the chassis.
  2. In the navigation pane, expand Configuration > Graph.
  3. Select Chassis.
  4. Select the SNMP tab.
SNMP Field Descriptions
The following table describes parameters on the SNMP tab.
Name
Description
InPkts
The number of messages delivered to the SNMP entity from the transport service.
OutPkts
The number of SNMP messages passed from the SNMP protocol entity to the transport service.
InTotalReqVars
The number of MIB objects retrieved successfully by the SNMP protocol entity as the result of receiving valid SNMP Get-Request and Get-Next PDUs.
InTotalSetVars
The number of MIB objects altered successfully by the SNMP protocol entity as the result of receiving valid SNMP Set-Request PDUs.
InGetRequests
The number of SNMP Get-Request PDUs the SNMP protocol accepts and processes.
OutGetRequests
The number of SNMP Get-Request PDUs that are generated by the SNMP protocol entity.
InGetNexts
The number of SNMP Get-Next PDUs the SNMP protocol accepts and processes.
OutGetNexts
The number of SNMP Get-Next PDUs that are generated by the SNMP protocol entity.
InSetRequests
The number of SNMP Set-Request PDUs the SNMP protocol accepts and processes.
OutSetRequests
The number of SNMP Set-Request PDUs that are generated by the SNMP protocol entity.
InGetResponses
The number of SNMP Get-Response PDUs the SNMP protocol accepts and processes.
OutGetResponses
The number of SNMP Get-Response PDUs that are generated by the SNMP protocol entity.
InTraps
The number of SNMP Trap PDUs the SNMP protocol accepts.
OutTraps
The number of SNMP Trap PDUs the SNMP protocol generates.
OutTooBigs
The number of SNMP PDUs the SNMP protocol generates for which the value of the error-status field is tooBig.
OutNoSuchNames
The number of SNMP PDUs the SNMP protocol generates for which the value of the error-status field is noSuchName.
OutBadValues
The number of SNMP PDUs the SNMP protocol generates for which the value of the error-status field is badValue.
OutGenErrs
The number of SNMP PDUs the SNMP protocol generates for which the value of the error-status field is genErr.
InBadVersions
The number of SNMP messages delivered to the SNMP protocol entity for an unsupported SNMP version.
InBadCommunityNames
The number of SNMP messages delivered to the SNMP protocol entity that used an SNMP community name not known to said entity.
InBadCommunityUses
The number of SNMP messages delivered to the SNMP protocol entity that represented an SNMP operation not allowed by the SNMP community named in the message.
InASNParseErrs
The number of ASN.1 or BER errors the SNMP protocol encountered when decoding received SNMP messages.
InTooBigs
The number of SNMP PDUs delivered to the SNMP protocol entity for which the value of the error-status field is tooBig.
InNoSuchNames
The number of SNMP PDUs delivered to the SNMP protocol entity for which the value of the error-status field is noSuchName.
InBadValues
The number of SNMP PDUs delivered to the SNMP protocol entity for which the value of the error-status field is badValue.
InReadOnlys
The number of SNMP PDUs delivered to the SNMP protocol entity for which the value of the error-status field is readOnly. It is a protocol error to generate an SNMP PDU containing the value "readOnly" in the error-status field. This object is provided to detect incorrect implementations of the SNMP.
InGenErrs
The number of SNMP PDUs delivered to the SNMP protocol entity for which the value of the error-status field is genErr.
