View application host statistics to see traffic statistics by application protocol for each host.
Switch:1# show rmon application-host-stats ? WORD<1-64> Select one of these application protocols {TCP|UDP|FTP|TELNET|HTTP|RLOGIN|SSH|TFTP|SNMP|HTTPS} Switch:1# show rmon application-host-stats FTP ================================================================================ Rmon Application Host Stats ================================================================================ HOSTADDR INPKT OUTPKT INOCT OUTOCT CREATETIME -------------------------------------------------------------------------------- 192.0.2.10 0 0 0 0 10/09/15 17:29:54
![Note](images/note.png)
Protocol support can vary across platforms.
The following table defines parameters for the show rmon application-host-stats command.
Variable | Value |
WORD<1–64> |
Specifies one of the following application protocols: TCP, UDP, FTP, TELNET, HTTP, rlogin, SSH, TFTP, SNMP, HTTPS. Note:
RMON2 can count application packets received on a platform, even if the application is not enabled or supported, before dropping them. |
