Display individual RMON statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View RMON statistics:
Switch:1>enable
Switch:1#show interfaces gigabitEthernet statistics rmon 1/13
Port Stats Rmon
PORT OCTETS PKTS MULTI BROAD CRC UNDER OVER FRAG COLLI
NUM CAST CAST ALLIGN SIZE SIZE MENT SION
1/13 1943 21 8 13 0 0 0 0 0
Use the data in the following table to use the show interfaces GigabitEthernet statistics rmon command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
