Use the forwarding database for VLANs to determine how the system forwards a received frame.
- In the navigation pane, expand
- Select VLANs.
- Select a VLAN.
- Select Bridge.
- Select the Forwarding tab and the VLAN forwarding database information is displayed.
Forwarding Field Descriptions
Use the data in the following table to use the Forwarding tab.
Name |
Description |
VlanId |
Address |
Specifies a unicast MAC address for which the bridge has forwarding or filtering information. |
Status |
Specifies the status of this entry. |
Port |
Specifies either a value of zero (0) or the port number of the port on which a frame having the specified MAC address was seen. A value of cpp indicates a self-assigned MAC address. |
Cvid |
Identifies the customer VID for this interface. |
