Edit the IPv6 PIM parameters for an interface to customize the IPv6 PIM configuration.
- Select IPv6 PIM.
- Select the Interfaces tab.
- Configure the required parameters
- Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
Name |
Description |
IfIndex |
Shows the interface Index. This variable is a read-only field. |
Address |
Shows the IPv6 address of the PIM interface. This variable is a read-only field. |
NetMask |
Shows the network mask for the IPv6 address of the PIM interface. This variable is a read-only field. |
Enable |
Shows the configured mode of this PIM interface. sparseDense mode is valid only for PIMv1. |
Mode |
Shows the configured mode of this interface. The valid modes are SSM and sparse. This variable is a read-only field. |
DR |
Shows the router with the highest IPv6 address on a LAN designated to perform these tasks. |
HelloInterval |
Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default is 30 seconds. |
JoinPruneInterval |
Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default is 60 seconds. |
OperState |
Indicates the status of PIM on this interface: Up or Down. |
Type |
Specifies the interface type. |
