Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
  1. In the navigation pane, expand Configuration > IP.
  2. Select PIM.
  3. Select the Virtual Neighbors tab.
  4. Select Insert.
  5. Specify the IP address of the virtual neighbor.
  6. Specify the interface index for the PIM interface.
  7. Select Insert.
Virtual Neighbors Field Descriptions
Use the descriptions in the following table to use the Virtual Neighbors tab.
Name
Description
Address
Specifies the IP address of the neighbor.
IfIndex
Specifies the IP address of the PIM interface.
