Use this procedure if you want the switch to support advanced features. When you enable the boot flag, you need to save and reboot with the new configuration.
high applies to 5720 Series, 7520 Series, and 7720 Series.
low does not apply to 5720 Series.
vim does not apply to 5320 Series, 5420 Series, 7520 Series, and 7720 Series.
A message displays to remind you that the configuration cannot include reserved ports, and that you must save the configuration and reboot the switch for changes to take effect.
If you selected No, you can modify your switch configuration to remove the reserved ports and then return to this tab to change the AdvancedFeatureBWReservation configuration.
