Enable Jumbo frames to increase the size of Ethernet frames supported on the chassis.
  1. On the Device Physical View, select the device.
  2. In the navigation pane, expand Configuration > Edit.
  3. Select Chassis.
  4. Select the Chassis tab.
  5. In MTU size, select either 1950, 9600 or 1522.
  6. Select Apply.
