You can only use this command on a switch with boundary-node abilities.Perform this procedure to specify the IS-IS area where Auto-sense creates a specific ExtremeCloud SD-WAN-learned tunnel. This configuration overrides a global area configuration for all learned tunnels.
The following table defines parameters for the auto-sense sd-wan multi-area logical-intf-dest-ip {A.B.C.D} <home | remote> command.
| Variable | Value |
| {A.B.C.D} | Specifies the destination IP address of the SD-WAN logical interface. |
| <home | remote> | Specifies the IS-IS area as home or remote. By default, Auto-sense creates SD-WAN logical interfaces in the home area. |
