You can only use this command on a switch with boundary-node abilities.Perform this procedure to create all ExtremeCloud SD-WAN learned tunnels in the IS-IS remote area. You can also configure exceptions for specific tunnels. For more information, see Configure the IS-IS Area for a Specific Tunnel.
By default, Auto-sense creates SD-WAN logical interfaces in the home area.
enable
configure terminal
