Configure the maximum EAP requests sent to the supplicant before timing out the session:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 1/2 Switch:1(config-if)#eapol max-request 10 Switch:1(config-if)#eapol port 1/2 quiet-interval 500
The following table defines parameters for the eapol port command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} | Specifies the port or list of ports used by EAP. Identifies the
                                    slot and port in one of the following formats:
| max-request <1-10> | Specifies the maximum EAP requests sent to the supplicant before timing out the session. The default is 2. |
| quiet-interval <1-65535> | Specifies the time interval in seconds between the authentication failure and start of a new authentication. The default is 60. |
| re-authentication enable | Enables reauthentication of an existing supplicant at a specified time interval. |
| re-authentication-period <0, 60-65535> | Specifies the time interval, in seconds, between successive authentication. Configure the value to 0 to prevent EAP or NEAP sessions from aging out. Caution: Preventing re-authentication can introduce a
                                    security risk.  The default is 3600 (1 hour). |
| status {authorized|auto} | Specifies the desired EAP authentication status for this port. |
